A storyline included to give the context.
In order to find parts, I needed to change crankset to get another chainring bcd.
Because the bike showed a chain tension variation, II chosed for Octalink 1 system, because my previous singlespeed later fixed bike with Octalink 2 (2!) didn't have such a tension variation.
But no luck, still a variation. Likely because version 2 is one piece at one crank side so machined together, maybe easier to center.
Then the bottom bracket failed, alot play, and has been replaced by dealer by a model that required increasing the thread diameter inside the frames bottom bracket based eccenter module ment to tension the chain.
After done, subsequent weeks, months, the left crank came lose over and over again, so that I started to check after every ride and even stop during, to notice that I could retension the bolt again (big size allen key)./
Went to the dealer with it, he used a BIG allen key to fasten it, I thought solved but no, couple weeks later the crank fell again off.
The dealer upon asking did not provide a solution. So I messed on a week further, to then notice that the bolt ceased to come lose.
No idea why, it stopped without apparent reason, and it's now 9 or so months further..
Yesterday, some guy on an electric step was riding while staring straight down to his computer in the middle of his handlebars, crossed a T where I came from the right, and hit me in my side. Me and quite heavy loaded bike were thrown to the right side.
I had nothing, bike minor damage, some luggage broken but cheap 5 euro and the guy paid it.
However, an hour later, my right pedal shifted sideways alot over its axle, both pedals were worn alot, alot play, since a year, but I just keep oiling and using them, and carry spares in case. That saved my yesterday, to get back home.
Now today I decided to replace the left pedal too, and noticed that when I put alot force to tension it, my left crank moved over a short angle. The allen bolt could be tensioned a half turn further. This late afternoon after a 25 km ride, checked, could again tension abit further.
Remember, this is the left pedal, crank, NOT the side the bike fell on its side yesterday.
So I now don't know what to make of it.
Octalink is a splines shaped cross section, with a certain overlap, which is longer on version 2 than on version 1.
When the dealer loosed it completely back then, the splines showed no damage, despite crank felt off several times under heavy load, because I then didn't know what was going on, I felt something moving but kept on pushing.
So this is weird, no damage, still, the crank still losening (sometimes?).
Don't know what to make of it, I dont want to risk a damaged crank connection leaving me stuck somewhere, but the risk is unclear to me since I don"t understand what's going on here.
Clues?
Clues?
