ericmark
- Llanfair Caereinion, Mid Wales.
A thought, where I use to live there was a park, actually called Alan Park after the river, where they hired out bikes for the disabled, most were three wheel jobs, all seemed hefty, and the advantage with three wheels you can go slow without falling off, these had very low gears.
The mountain bike clearly good, but depends on location. I have used the canal tow paths as level and so gets one started, but they vary so much, tried the Shropshire Union (Llangollen) Chirk to Montgomery and some parts were unridable but once on the Montgomery canal a lot better, there are also old railway lines, Shotton to Chester (except for the bridge which is a little steep) and the Dolgellau to Barmouth is very good.
I found being able to sit down I could get my exercise, not as heavy as you, but I was, well still am on the heavy side, wife has an electric bike, but weight limit is a problem, the Gtec bike has a very low maximum weight. However once your weight is down a bit they do open up what routes can be used, I find under 4 MPH balance becomes a problem, does not matter how low the gears will go, if you can't balance then can't ride it. That was where the electric came in it allowed me to go just that little faster on inclines.
As well as mountain bikes, shop bikes are also designed to take extra weight, they are low geared and sturdy. Other option old moped with motor removed, again very low gearing and will take the weight.
. I would love to be able to speak to him for advice.
