Come to think of it, I think it was you who caused me to buy 2 litres of Coca Cola!2902115 said:Wear clothes, that should keep your todger away from the saw.
Is there any health risk with sawing and breaking up a carbon post?
Steel frame, alloy post and I gave up its still stuck@simon the viking: What frame material was it? Mine is the 4130 CrMo alloy.
I don't bother myself with cash, dear boy. Back from the East, Dave?Only to your wallet.
But I expect you have difficulty opening that, as well.![]()
No! Damn it!!Hello Rich.
Yes, but only temporarily (father-in-law died, back for the funeral), off again asap.
Get the Chrissy card I sent?
No! Damn it!!
p.s. sorry about FiL
I've seen that suggested for alloy seatposts in steel frames, but I'd have zero confidence for carbon in aluminium..Coca Cola down the seat tube from the bottom bracket was the weirdest.
+1 But you may have trouble getting hold of ammonia. Caustic soda (Sodium Hydroxide) will also dissolve aluminium without attacking the steel frame. Sometimes you can buy it for unblocking drains, as it's also very good at shifting fat deposits.OP if its an alloy post or alloy frame, the easiest way to remove it is with ammonia it eats the oxidised gunk to nothing, making it easy to twist the stuck post.
No worries... I'll just start looking for a girl who likes to get it off!give it to a girl and then when she gets it off you can say "i probably loosened it"![]()
For an aluminium seatpost stuck in a steel frame, the "nuclear option" is to use caustic soda (sodium hydroxide, commonly sold as a drain cleaner). It will just dissolve the aluminium out (may take 2 or 3 days). It's nasty stuff,and can generate enough heat to fizz and spit, so good coverage rubber gloves and eye protection (at least) is required.
