Ghost Donkey
Apart from money the software consideration is an issue. If video quality is an issue windows movie maker is pants. The basic edits such as cuts and fades render very badly (not a hardware issue, it's not done real time). You can however get adobe premiere elements which is much cheaper than the full version and will most likely do what is required. Premiere is pretty easy to get used to and teenagers are especially good with this kind of thing on any platform.
Imovie on the mac is much better than movie maker but still only has one video channel. The interface is userfriendly and I like it. If your son only needs one video channel it won't be a problem. If you have compatible hardware avid free DV was always good but you most likely won't have compatible hardware. It uses the same interface the higher end avid software which I used to be familiar with so was a doddle for me to get around but I couldn't digitise or import video which made it useless on my machine.
If you get a PC there are several good editing packages available which may prove to cost less than a mac.
As for web design it again depends on his needs. I've been trying to learn how to do it in notepad which means I have to learn it and how it works properly so I can support it better. There a lots of free web editing software online or installable.
