mjr
- mostly Norfolk, sometimes Somerset
I've just dug out my individual consultation response. I've cut the preamble - here's the core of it:
I am disappointed that a narrow two-way cycleway with centre line is being proposed. This seems to be based on the discredited idea of dual provision: abandoning "experienced cyclists" to keep suffering the road (now with increased "use the cycleway" abuse from motorists?) and a slower dangerous cycle track for everyone else. I utterly reject the implicit idea that "experienced cyclists" wouldn't use a decent cycleway if it was built and I urge you to show some ambition. I thought this was being funded by a grant with "Ambition" in its name?
As you know, a single 2.5m bidirectional track is too narrow to allow cycles to ride sociably side-by-side or overtake safely while passing oncoming cycles. A centre line is likely to become slippery when wet and riding on the right "salmon-style" makes it difficult for cycles to move safely to/from the all-traffic lanes if relative speeds/flows mean that would be a good move. [note: long after consultation, they widened the Tombland part and turned the Palace Street part into narrow advisory lanes because this width is silly; the centre line has gone, but the track is still one-sided and hard to move on/off the carriageway if needed.]
The best practice, illustrated on page 17 of Making Space For Cycling (available from www.MakingSpaceForCycling.org ) is for protected cycleways on each side of a road. There is definitely space for this on Tombland and if there was the will to reallocate space a little more on Palace Street, there would be room there too. In the current design, the biggest beneficiary seems to be pedestrian space (23% of space is reallocated to them) which seems a little odd for a project funded by a cycling grant when there is an obvious need for a bit more space for cycling than in these initial designs.
I think some attempt should be made to facilitate cycle access to/from Wensum Street and thereby to Anglia Square or to Colegate towards Marriott's Way. The FAQ calls this "the main route for both buses and cycles", so I'm surprised that turns to/from the cycleway are impossible in the proposed design. [note: the final version has the tiny filter/escape that I photographed earlier]
I guess that riders may be meant to use the pedestrian crossings to leave the cycleway to turn down Wensum Street, which seems likely to surprise both walkers and motorists and therefore be an avoidable safety hazard. Riders not familiar with the area will probably not realise the turn into Wensum Street is impossible until beyond the courtesy crossings and bump down the kerb near the new T junction, which is a riskier movement. This would be remedied by the solutions described in Making Space for Cycling.
Cycles making the right turn into Palace Road should be protected primarily by a west-side cycleway continuing on the same level over a smooth-radius perpendicular crossing of the mouth of Wensum Street with priority, possibly combined with a pedestrian courtesy crossing, while riders continuing down Wensum Street are merged onto the all-traffic lane. Of course, in the interests of keeping traffic flowing, people should be allowed to ride salmon-style on the right around the corner if they wish and an opportunity to cross Tombland further south presents itself.
I agree with the cycleway being at an intermediate height but some drawings show frequent "rumble strips" of cobbles across the cycleway, while the rest of the surface seems to be some sort of small-block paving. Unless the aim is to deter most people from using the cycleway as some sort of "look, we built it and they still won't use it" demonstration, the cycleway should be a suitably-coloured Hot Rolled Asphalt 55/10, Asphalt Concrete 10 or something similarly smooth.
...and it then continued into objections to various technical details of their plans, most of which aren't present in what they built. So basically "I told you so", but it's not quite as lethal as the bike-grinder that was originally planned with pedal-catchers, cobbled rumble strips every few feet and emerging blind onto corners at both ends. Still pretty disappointing, though.
