non drive side crank arm coming loose
400bhp
I have a feeling i need a new crank but thought i would ask the peeps here...
I was riding up a steep hill a week ago and the non drive side crank arm fell off:rolleyes:
On closer inspection the safety pin had sheared in two
I put it back on, tightened it up and continued on my way
Got home and took it off and put it back om agaim
Anyway it has fallen off again today.
Its a hollowtech 2 fitting
Doing a short google search suggests the crank splines are probably worn due to the crank possibly being loose for a while. The crank is 18 months old and hasnt been removed from new
Any thoughts or experience?
Hampshire
Not sure what you mean by the 'safety pin'?
Andrew_P
In between here and there
Similar happened with my 105 only mine chewed the splines as I stood up to pull away and was stuck at 6 o'clock (the same as the drive side) I had to ride home one legged. ^_^
I would definitely replace it, mine was my fault as I had changed the BB 3-4 months before, never could really figure out what the pin was going to do. It was working it self off on the ride and I did the same as you
400bhp
400bhp
Thanks. It's not chewed the splines, but I wonder if it's gone out of shape/worn the splines?
What about swapping the bb?
400bhp
400bhp
400bhp
400bhp
Above is the offending crank. You can just about make out the indentations that have been caused by the crank shuffling about.
New crank ordered now.^_^
Andrew_P
I hadn't torqued the crank arm properly when I changed the BB I think mine chewed as it was on the edge of coming off, if you are changing the cranks you may as well do the BB, 105 Hollowtech II around £20
I hope the missus didn't see you putting oily bike parts on the kitchen top ! :whistle:
