figbat
Slippery scientist
- South Oxfordshire, UK
The rear wheel on my 29er hardtail is quite noisy. It appears to be the spokes and with a bit of pinching they seem a little loose. The wheel went in new a few months ago and seems to be true. It’s set up tubeless and adding pressure to the tyre reduces the noise.
Sheldon Brown says that if all spokes are loose you work around the wheel spoke by spoke with the same turn. I’d have guessed it might be better to do it at 180° or 90° intervals around the wheel.
Any advice? I’ve never touched spoke tension before.
