Yellow Saddle
- Loch side.
I do put a bead of grease around the collars to help prevent water getting in though
No, never do that. Grease is not to be used as a waterproofing agent, especially where there is relative movement between components. The reason is that grease easily emulsifies in the presence of water and movement. Emulsified grease is bad news in that it prevents water from evaporating and thus preserving its presence to do damage over the long term. An emulsified grease joint is in other words, permanently wet. Wetness not only promotes oxidation type corrosion (rust etc) but also promotes very damaging galvanic action. This applies to carbon and aluminium in particular.
