When planning a ride should I assume
- 25kph rolling average means about 550Kcals/hr of energy output
- max rate of ingestion/input is about 350Kcals/hr
- glycogen bank is about 1200Kcals
- bonking occurs when glycogen is depleted - say 6 hours on the above assumptions?
The max rate of ingestion asssumption is particularly open to comment please.
I know that there are a huge numberof variables that will affect these assumptions and conclusion but nonetheless a rough and ready calculation seems useful to me.
Not all of your calories expended need come from your calorie intake.
As the saying goes: "Fat burns in a carbohydrate flame". At low intensity (cruising on the flat) you could be burning 50% fat and 50% carbs. At this lower intensity, say 400kcal an hour, you'll be getting 200kcal of that energy from your fat stores and 200kcal from blood sugar, which is easily replaced by eating (since you can ingest ~350kcal an hour).
The faster you go the more inefficient your body gets at using fats, since it just can't metabolise it into energy fast enough, so it uses more glycogen.
So at 550kcal an hour (25kph rolling) it might be 70% CHO and only 30% fat. 70% of 550kcal is 385kcal, which is just above that 350kcal ingestion figure, but 1200/35 = 34 hours that you should be able to keep that up. (based on those figures).
Obviously the CHO:fat burn ratio will differ for individuals, and also even during a ride as the body's physiology changes. There's no magic formula.
I've done a 200km Audax (in just over 13 hours elapsed) without eating during the ride (and no breakfast, the last food was some 8 hours before I started). That's close to ~5000kcal expended with 0 intake.
Just eat little and often whilst moving and stop for a larger feed (cafe or petrol station) along the way. I did 1400km of London-Edinburgh-London in 116 hours with meals every 4-6 hours or so. Nom nom nom.
