Ni-cad chargers for Nimh
Chargers for Nimh
Will my old Ni-cad charger work with modern batteries or is the charging cycle different?
Reason is my Nimh chargers gone on the blink and I've only got my old charger left.
Mr Phoebus
Many of the older NiCd chargers are the simple timed type charger which will charge batteries for a fixed amount of time and then shut off. Unfortunately, since NiCd batteries have a much lower capacity than NiMH batteries, the timer is likely to shut off long before the NiMH batteries are fully charged. This won't harm the batteries, but the NiMH batteries won't be fully charged since the timer will have stopped the charge cycle too soon.
C
Crackle
Thank you Mr Phoebus, you have confirmed my suspiscions. New charger required then.
Now can I have another post, I was so disappointed to not read a funny post from you.
Mr Phoebus
I feel a right Bastard now.
Can you recommend a decent chain splitter, I need to apply some self flagellation.
ColinJ
Puzzle game procrastinator!
Crackle said:
One more serious question. Any old Nimh charger or should I look for summat specific?
The more sophisticated (expensive) ones will probably charge quicker and look after the cells better.
There's a lengthy article about the subject here.
I got my batteries and charger here.
jimboalee
Solihull
C
Crackle
Which one did you get ColinJ?
Quite a bit of reading to absorb so far.
andrew_s
Gloucester
jimboalee said:
www.maplin.co.uk/Module.aspx?ModuleNo=219129
Don't bother with a NiMh commercial charger.
I wouldn't advise using a power supply as a charger. There's nothing to detect full charge, so at some stage you'll give a cell too long and cook it, even if you do wait until they are flat before charging.
It's worth getting a decent smart charger that will detect end of charge in the long run.
Most chargers are 2 or 4 cells only, but something that will charge odd numbers of cells is important if you use devices that take an odd number, such as a Petzl headtorch. It's also good if you get one dodgy cell in a pack of 4, which isn't uncommon. They generally recover after a couple of cycles, but not if you damage them further by using/charging as one of a set/pair.
I use a Maha WizardOne. Others you might like to look at are the Ansmann Globe 4 or the Technoline BL-700
jimboalee
Solihull
andrew s.
I've been using a power supply for years. Got it on a digital timer, so no burn-ups.
Big powerful diode protection.
Only a suggestion if anyone is a sparky.
C
Crackle
Might go for this. Not as fully featured as andrew_s's but it's intelligent and will do some basic conditioning and takes the full range of batteries.
