Nexus 8 and Alfine 11
CXRAndy
Lincs
The hub was lubricated a month ago..
Did you strip the hub down to place lubrication or was it dipped in ATF oil?
GuyBoden
Warrington
I took my wife's internal Alfine 8 hub gears apart because they weren't working when I bought the bike cheap.
They are not too complex, but you need to clean them with degreaser, check for wear, fill them with semi-fluid grease and seal the hub so that the semi-fluid grease doesn't leak onto your disc brake.
Pegasus00
Regular
Lithuania
Need help. What length of BB do I need to get a straight 42mm chainline on this set? Crankset is Shimano Nexus FC-C6000, hub Alfine SG-S70001-8. 112mm or I'm wrong? Confusing calculations .. Thanks for help.
