Tigerbiten
Two things to think about is both the gear range and the gear bias.
Old school gears which I grew up with tended to have a 3x range, 100"-35".
I could just hit 30 mph pedalling downhill and +20% hills where hard work.
Modern gears tend to have a 4x-5x range.
The bias is where does most of that extra range go.
Typical road type bikes tend to be biased high, 125"-35".
They're great if you want to pedal downhill at 35 mph but you'll still struggle a bit on +20% hills.
Touring/MTB type bikes tend to be biased low, 100"-20".
You'll still have to work hard to hit 30 mph downhill but even +25% are easy.
Over a 6x range is possible if you want to push the limits, just not standard.
My bent trike is very non-standard with a 19x range .......
So think about your riding style and what you want out of your new bike.
Then think about which way you want to bias the gears, "fast down" or "easy up" ??
If you pick "fast down" then the small chainring will be bigger than the big sprocket.
If you pick "easy up" then the small chainring wants to be smaller than the big sprocket.
This will give you an idea of what's the gearing like on a bike and will it suit you with just a quick look at the specs.
Luck ............
Luck ............
