newbie just checking - loose cones
John the Canuck
..a long way from somewhere called Home..
got a Trek FX 7.2 - not used for ages
out for a 6m run - bit of directional control problems
checked back at home - loose front hub cones..
stripped - lubed - refitted loosely - ordered and waiting for cone spanners
the rear hub felt a bit 'gritty' [ too tight.?]
stripped - cone surfaces OK - lubed - refitted loosely
anything else i need to look for.?
PS
cleaned black gunk off the rim braking surfaces
do you have to clean the actual brake shoes as well.?... with.?
I'll be getting Kool Stop Salmon soon
thanks....john
the snail
Chippenham
thanks....john
clean up the pads and check for grit/metal flakes in the grooves or embedded in the rubber, and pick them out. It's worth doing this regularly, especially after wet rides or if you hear graunching sounds, or if there is black stuff on the breaking surface - that's your rims being ground away, and you can wear out the rims really quickly if you leave it. (DAMHIKT)
