- Manchester
I assume the quick release is not really, really, really tight?
I had mine done up too tight once and it did make riding harder work.
What exact (if you know) model of hub, please? Or maybe a link if you bought it online.New wheel was a bottom end of the market Shimano wheel (about 70 quid)
I believe it was that oneWhat exact (if you know) model of hub, please? Or maybe a link if you bought it online.
This one? http://www.chainreactioncycles.com/shimano-rs11-road-rear-wheel/rp-prod112040
Are the bearing cups so tight they are stopping it rotating freely ?
Cup n cone or cartridge bearings ?
RS11s "The hub uses angular contact bearings designed to cradle the balls giving both radial and lateral support for superior strength and durability in real world riding conditions. They also offer precision bearing adjustment and easy maintenance" Proper cup and cone bearings.I would have thought that tight cones and bearings would show up
Most likely (as several others have said - try a less tight QR). I'd also be tempted to look at the bearings and push a bit more grease in, however 'dry' they aren't.it would point to the loading on the axle bearings when being ridden as at fault
Has the OP done this test? Then replicate (for assurance) with the bike the right way up (ie lifting the rear wheel off the ground/floor).If the wheels spin under the weight of the valve when it is in the ten or two o'clock position there is nothing wrong with them. Try that.
My plan is use it over the weekend, and if there's no change, I'm definitely taking it back on Monday. I want to be sure first, I've a reputation to protectTake it back , fitted by LBS but not right .
Just come back from a ride and didn't have any problems today
Or something was a bit stiff to start and it's just loosened up with ridingIn that case you had a mystery visit from the bad day on a bike fairy, we all have them, some more often than others.
Your legs.Or something was a bit stiff to start and it's just loosened up with riding
