New version of tyre is (much) smaller than outgoing model... am I within my rights to return them?
Ajax Bay
East Devon
All I wanted was something 2-3mm taller/wider.......
And you didn't get it, did you. Good advice from @potsy, but for next time.
Ajax Bay
East Devon
If you get special pleasure from succeeding in an epic struggle to fit a tight tyre which is a 'mare to get on a rim, then do not use talc. And also expect to struggle by the roadside the first time it needs taking on and off.
Ajax Bay
East Devon
To measure a tyre section, ETRTO has defined:
  • The rim width on which each tyre section must be measured
  • The pressure at which it must be measured, taking into account that the casing of a brand new tyre will stretch within the first 24 hours of inflation, so the measurement should be done after those 24 hours
For example, a tyre said to be a section of 23mm should be measured on a rim of 15mm internal width at 6 bars (87 PSI) after 24 hours.
A tyre said to be a section of 28mm should be measured on a rim of 17mm internal width at 6 bars (87 PSI) after 24 hours.
the-right-tyre-width-on-the-right-rim-width/
Poacher
Gravitationally challenged member
Nottingham
Must be a youngster that posted that!
:rofl:
ayceejay
Rural Quebec
Sure enough the new gap is bigger
