The Cateye Volt 700 has a fairly focused spot beam. The 300, 400 and 700 have scored highly in reviews.
I have the Smart 700 usb for around a year now...I really like the long run-times and use it on medium, low, and strobe for daytime use. Not sure I will use strobe settings anymore... (6hrs/350lumen,10hrs/220lumen) it does not seem to get hot on the medium setting. I rarely use the maximum setting. Plenty of light power for total darkness.
The beam pattern is spread and you can see about 20 metres in front of you, personally I would rather a more 'spot' beam with a bit more throw...having said that, it was only 30 GBP's...a bargain.Anyway, am really happy with it.
The wide beam pattern probably makes it a better light for cornering / off road / paths etc. The downside is you are more likely to annoy others.
I've got a collection of Smart Lunar's: 35 lux, 60 lux and a Blaze 2 watt, all have the same mounts so with 2 mounts I usually run the 700 with the 60.
All the Lunars are very much focused spot beams. (maybe the Blaze - less so) The 60 is amazing for a 2 x AA powered light! Can't really tell the difference between the 35/60...
Planet x are selling Lunar 60's for peanuts at the moment.
