Sloth
So I got my sit bones measured at a shop today, I measured them at 110mm (using tin foil and piece of carpet) and they measured them at 115mm so I wasn't far out.
I was advised that I needed a saddle width of around 140-145mm width and that too wide may cause more problems.
I tried a couple on the bikes in the store but no matter which one I tried I felt uncomfortable pressure, not on my SB's but rather at the very top of my inner thighs, right at the top near my buttock in the crook between my berries and my leg but on the leg side.
It felt like the edge of the seat was digging into me there, kind of like it was pushing onto some tissue there.
Both saddles were Gel but also fairly firm padding in their feel to me.
Anyway, I'm more confused than ever.
Would a seat that was over 140mm wide at the back but very quickly tapered to a thin nose help?
Should I go for a extra padded saddle and hope it compensates for my seemingly odd and unforgiving anatomy?
One of the saddles was I believe a specialized-phenom comp and the others name escapes me totally.
Some of the pressure could undoubtably be due to me just sitting on the saddle on a stationary/propped up bike with most of my weight bearing straight down. I did lift my feet into a more peddling type position but it's hard to get an accurate feel without actually riding.
The pressure I feel is focussed on the part of the saddle where the wide section at the rear curves into the narrower nose section, give or take depending the saddle. Not on the rear where my sit bones should be but in the curve on the sides. Like the edge of the seat is digging into me.
I'm wondering if a saddle that continues the padding around the sides and partially under the sides, rather than simply stopping (leaving a hard edge on the sides of the seat) will help?
Are SMP TRK's like that? Which other saddles have gel/padding that wraps around the sides rather than only going to the edge?
Just a thought as I'm out of ideas!
