Paul_Smith SRCC
www.plsmith.co.uk
- Surrey UK
Assume you mean between Secteur and Tricross? If yes then the Secteur should indeed feel more responsive than the Tricross; it is set up to be.Norm said:...The difference between the two is quite significant, given that I have them both set up very similarly. There's only a 1kg overall weight difference but even I can feel that the Secteur is way more responsive.
The Tricross is set up to be more versatile with larger clearances for larger tyres, this will allow for towpath riding and as such the bike will have a more heavyweight construction to accommodate that kind of terrain, as such whatever you do to it don’t expect it to feel as responsive as the Secteur. Vice versa applies of course, you can fit Clip on guards and a pannier rack to a Secteur, yet it will never feel as robust as a Tricross or feel quite as stable loaded with luggage, neither will it cope with towpath tracks as easily.
For sure it is all relative in as much where Norm states "Secteur is way more responsive" others may feel less of a difference. However the fact that there is a difference means it is worth making the effort to make sure you get the model that is best set up for you personally. Alteratively; working on the theory that the ultimate number of bikes is exactly what you already have; plus one; then get both
Paul_Smith
www.corridori.co.uk
