New cassette
Bman
Herts.
So, Ive left my chain far too long between replacements, so now I need a new cassette. (the chain is stretched and I am starting to get a little bit of skipping when changing gears). :sad:
Having never changed a cassette before, I could do with some advice:
It appears I have a Shimano HG-50 8-speed Cassette on the GTR, but which type, I couldnt tell you.
http://www.chainreactioncycles.com/Models.aspx?ModelID=1864
CRC sell that cassette, but what "options" do I want? 12-21? 12-23?
Ideally I want to swap like-for-like, but how do i find out what size I currently have?
Also, what tools will I need to swap the cassette?
Count the number of teeth on your present cassette?
Cassette tool for Shimano hyperglide, Chain whip, and a torque wrench (capable of 40nm iirc)
RecordAceFromNew
Swinging Member
West London
Fwiw I have never used a torque wrench for cassette installation. Just do it up tight will be fine since pedalling tightens a cassette or freewheel anyway.
Imho Sram 8 speed cassettes are superior to Shimano's and they are interchangeable.
wakou
Essex
+1 to no torque wrench needed. Lock rings have grippy splines, just tighten till you hear feel several cicks from them and you are good to go. Do NOT overtighten!
Bman
Bman
Herts.
I didnt realise it was as simple as counting the teeth :smile:
I need a 12-25. Looking at a few youtube videos suggests this is quite simple.
Thanks for the confirmation on not using a torque wrench, I was siding with the idea and had figured out about pedalliing rotation from the vid. Looks like i'll be safe without :smile:
Moodyman
You need strong arms the first time you take off the the worn out cassette. At first it feels like nothing's happening, then suddenly the joyous crunch,crunch of it getting it loose.
Bman
Bman
Herts.
LBS quoted £30, I can get the tools and parts to do it myself for £35.97.
ID Unit Price
11260 Shimano Tiagra Cassette 8 Speed HG50 18
130729 Shimano HG40 Chain 7/8 Speed 6.99
31722 X-Tools Chain Whip 5.99
24538 Cyclo Pro Series Cassette Lockring Remover 4.99
Seems like a no-brainer :smile:
RecordAceFromNew
Swinging Member
West London
ID Unit Price
If you haven't ordered already, don't get a Shimano chain. Get a KMC chain instead.
+2 for no torque wrench required, and +1 for KMC chains. I switched to them a while back and won't use anything else now :thumbsup:
Herzog
Swinglish Mountain Goat
And hopefully the skin of your knuckles will still be intact (I speak from experience).
Bman
Bman
Herts.
I havn't ordered yet. Just a few days until payday.
What makes the KMC chain better than the Shimano?
