Very nice.
You need to rotate the handlebars a little. the bar end plug should point towards the rear brake or just above it.
It's okay listening to other people to find a starting point for your bike setup, but ultimately it is your body and that's what you should listen to.Cheers Gaz! I've played around with them a little and the picture angle probably doesn't help but i'll have a look at moving them slightly.![]()
I'd have guessed that. Your bike is about the same size as mine and I'm a smidge over 6' 1".Thanks guys! Not sure about very tall, i'm 6"2.![]()
How do you brake in the drops? Probably ok if it's just a small angle, but anything too big and then there is no point having drops.I used to go for the 'correct' bar set up and then I noticed that a lot of pros were tilting their bars back slightly to get a more comfortable position when riding on the hoods. I tried it and found that it eased a lot of the discomfort I was getting in my wrists on long rides.
It does make braking slightly harder from the drops, but I don't have particularly long fingers and I can still manage it. I agree that you don't want the bars tilted back by a huge angle.How do you brake in the drops? Probably ok if it's just a small angle, but anything too big and then there is no point having drops.
