Widge
Baldy Go
...I thought I had really nailed the thorny old size/comfort question on the road bike I have been riding since 2012. Indeed, my trusty 54cm size 'Triban' fits me like a glove after a few 'tweaks'.
Now I am contemplating the purchase of an Orbea 'Gain' electric assist road-bike since I am trying to recover from an illness which has kept me off the road. (I'm not getting any younger and live in very hilly s. Devon!)
I am a little over 175cm (5ft 8ish?) with a 30in inside leg and shortish arms but when I look at the Orbea sizing chart for my height it suggests a 55.5cm 'Medium' size which looks a fair bit bigger than my Tribby in every respect. SO....I am looking at the 51cm size Orbea Gain D50 (Small) which looks a closer approximation to what I am used to. In fact it looks marginally BIGGER?
I have the side-by side specs here,,,,, (54cm Triban and 'Small' Orbea)
Compare
T3 (54cm) / Orbea (Small)
Reach 394 / 387
Top Tube (eff) 541 / 546
Stem Length 90mm / 100mm
You can see that the major difference appears only to be 'reach' but even this works out pretty much the same since I fitted a 10mm shorter stem (90mm) to my T3 stem anyway.
Even the lowest cost d50 is a significant investment and the nearest shop is over 200 miles away. I suspect the dealers would merely quote the Orbea printed'size recommendation' for the larger 'Medium' if asked.
I don't want to get this horribly wrong!!
Help!! What do you think?
All Ideas and wisdom gratefully received.
All Best
widge
Compare
Reach 394 / 387
All Best
widge
