New bike or fix existing
Kevin ADDERLEY
Hi I got a speciLized cross trail with mudguards and that. Anyhow. It needs new transmission and shop says it will cost apprix 100 +. It is about 4 years old the question is shall I bother?
ianrauk
Tattooed Beat Messiah
Rides Ti2
Shall you?
Whilst £100 is a chunk of change it sounds cheap for a 'new transmission' and it's still a whole lot less than a new bike.
What exactly are you getting for your £100?
If you can afford to get a new bike though then why not, if you can't then fettle your current one.
Or, get a new bike and fettle your old one with second hand bits and keep it as a winter hack.
Options, options, options, but only you can decide.
K
Kevin ADDERLEY
It's needs chain back gears and front I think. Evans say it will be £117 which includes silver service. I can afford a newer one seen a cycle cross specialised tricross on e bay for £450 is that better value?
Not if it also needs a new transmission...is stolen...etc
Find a local bike shop, should be as cheap as Evans and they may well do a better job. Ask if they'll be happy to fit parts you source yourself online (if you do go with Evans, find the parts cheaper and quote their price match policy)
I like Skol
A Minging Manc...
Fix your existing ride. If you feel you can then learn to do it yourself. Changing the chain, cassette and a couple of chainrings at the front is simple wear and tear maintenance requirement.
I am a strong believer in fix rather than replace. My ethos is buy quality, buy once, and then look after it until it is beyond sensible repair.
Overconfidentii Vulgaris
I'd definitely repair. My best bike is on its 3rd drivetrain and the knockabout bike is on its 4th. In both cases they've been taken well away from their original spec so that the current gearing is what I want, not what some marketing guy thinks I should want.^_^
Edit: all work done by my own fair (if slightly scarred) hands.;)
I've got a 13 years old Scott YZ-1. It's had everything replaced multiple times, each time going up a notch in spec.
If I could upgrade the shitty chinese forks I would. It's served me well for thousands of miles so I'll keep fixing and fettling.
As for the £100+ quotes, shop around a bit.
the snail
Chippenham
buy replacement parts and the tools and do it yourself, then learn how to do routine maintenance - it's not difficult and there's plenty of advice on here and youtube etc
K
Kevin ADDERLEY
I don't have time to fix it myself or the tools or know how. I will ask the shop what they r charging me for and they said I need a silver service again not sure if I need thus or if I can do that in a other service later
