mickle
innit
- 53.933606, -1.076131
All of which is an excellent argument for buying your bicycle from your local bike shop.
looks like standard cup and cone , the outer cup silver has a nut head then a standard nut is on top of it , normally these have a rubber cover that is missing .Possibly sealed bearings?
Don't let them off the hook. Insist it is replaced, they clearly know something is wrong.Just had a call from them and they may consider sending another one and do seem genuinely aggrieved this has happened. So looks like its going to be sorted one way or another
99/100 I'd agree with you but for the OP I think "local" would be a long way to travel.All of which is an excellent argument for buying your bicycle from your local bike shop.
I’ve only bought one bike second hand reasonably locally but all the others have been online with no problems at all. Maybe just been lucky.99/100 I'd agree with you but for the OP I think "local" would be a long way to travel.
I think it's a personal choice. Clearly lots of people get on well with an online purchase. Years ago I wouldn't have the knowledge/confidence to buy online. I'd probably be OK now but after 20+ years with the same LBS I'm happy to stick with them.I’ve only bought one bike second hand reasonably locally but all the others have been online with no problems at all. Maybe just been lucky.
Similar exeperience.I’ve only bought one bike second hand reasonably locally but all the others have been online with no problems at all. Maybe just been lucky.
Im unfamiliar with quick release wheels so looking at the wheel sent i thought it was the wrong one ie a normal wheel Considering the other missing parts it was a reasonable assumption and i even discussed with e-bikes a cash adjustment my way for a standard wheel. So looking around the bike i tried the back wheel quick release....wouldnt budge. Then i thought i would try fitting the front wheel,,,,,nuts were screwed down tight and had to put a hell of a lot of pressure to get them to move and didnt feel right at all. The nut looks the same both sides as pic and im wondering if ive ******it up. It is the correct quick release wheel so it isnt a Frankenbike its just missing some parts.
the nut should be tight you dont undo it, it slots betwen the fork with the bit at the end resting in the fork notchThanks for all the repliesIm unfamiliar with quick release wheels so looking at the wheel sent i thought it was the wrong one ie a normal wheel Considering the other missing parts it was a reasonable assumption and i even discussed with e-bikes a cash adjustment my way for a standard wheel. So looking around the bike i tried the back wheel quick release....wouldnt budge. Then i thought i would try fitting the front wheel,,,,,nuts were screwed down tight and had to put a hell of a lot of pressure to get them to move and didnt feel right at all. The nut looks the same both sides as pic and im wondering if ive ******it up. It is the correct quick release wheel so it isnt a Frankenbike its just missing some parts. View attachment 609706
Thanks cyberknight, as ive undone them a way have i broken something?the nut should be tight you dont undo it, it slots betwen the fork with the bit at the end resting in the fork notch
https://www.parktool.com/blog/repair-help/wheel-removal-and-installation
no, to do it up properly your best to use cone spanners what it does it hold the bearings in place so they are supposed to be a certain tightness to hold everything in but no so tight that it stops the wheel spinning freely .Thanks cyberknight, as ive undone them a way have i broken something?
