Jhnbssl, I just ordered the same frame and was hoping you could provide some insight. I am told that I will also not receive frame accoutrements.
Are the cable fittings you used a standard DI2 fitting? I am mechanical cable guy and am looking for suggestions on where to buy tbe fittings. Also do your cables rattle in the frame? Have you put in any cable liner to deaden sound?
What size is tbe seatpost and what is the headset, a ZS 44/56?
Thanks!
@EvanAL Assuming yours is the same frameset as mine and is coming with no fittings at all as mine did you'll need to source:
- Correct rear thru axle - I used a Shimano E-Thru axle like this one. The nut on the end is castlated, you screw a bolt in from the rear of the drop out through the threaded hole in the frame to lock it in position once you've got it adjusted.
- Rear mech hanger - I bought one from SOS Hangers, where you'll need a D560 Bianchi derailleur hanger
- Metal screw-in cable inserts - These are Bianchi only parts, they'll need to come from Bianchi UK or a dealer. I walked in to my local dealer and rummaged through their spares and found all the bits I needed. There are different inserts for mechanical and di2 setups but as far as I can tell they're the same between different Bianchi framesets - at least the ones I've fitted to the Methanol are the same as the ones I had in my Oltre XR3
I put a few cable ties on the Di2 cables to stop them bouncing around inside the frame. I didn't put anything on the hydraulic hoses and they seem fine
The seatpost is 31.6mm on this one
The headset I used is an FSA Orbit tapered, 1-1/8" to 1.5", like this one
Hope thats useful, let me know if you've got any other questions
It's a beautiful bike to ride, good choice
