nickyboy
Norven Mankey
- You want hills? We got hills
Fitting mudguards can't be as hard as everyone makes out, can it? Damn right it is. Currently the bike is in the porch minus wheels and with about half of a mudguard completed.
Couple of questions regarding fitting SKS Chromoplastics to a Raleigh Airlight 100
1) All the bolts of varying lengths appear to be the same diameter. This is fine for the fixing point at the bottom bracket. But the holes for the brackets close to the brakes (front and rear) are too large for the bolts supplied. Any idea what size bolts would be required?
2) Regarding the bottom bracket fixing point for the back mudguard it seems the thread has failed. When I screw the bolt in the "cyclinder" turns so the bolt never fully tightens. Any ideas what do do? It will work completely loose if I leave it. I have heard some have used cable ties, any good?
3) Finally, when I was testing the rear wheel fit (despite the above problems) there was no clearance between the tyre and the bolt that goes into the bottom bracket fixing point. Couldn't jiggle it around to produce clearance. Any thoughts?
Thanks in advance. Cup of camomile tea needed now...
