I got my bike checked out after hearing some cranking noises coming from the bottom bracket. The noises occur occasionally whilst pedalling. Anyway the mechanic said the bracket has not been screwed tight enough, apparently not a wear and tear issue, it's something which the manufacturer didn't do, and this is what's causing the cranking noises. I've attached a photo here, apparently where the arrow is pointing, there shouldn't be a gap according to the mechanic.
What are your thoughts? Because I rang the online store where I bought the bike from, they looked at the photo and said that the gap is pretty normal for a tapered bottom bracket.
£30 to tighten up a square taper bottom bracket??? With the correct tools (which are not expensive) that is literally a five minute job. A cartridge B/B literally just screws in from the drive side and is then held by a screw in cup on the other. There is no fiddly adjustment required at all, so anyone who is charging £30 to do that is on to a good thing.
Are you sure the play is coming from between the B/B unit and the frame, or is it possibly that the axle itself is loose (indicating worn bearings)? If the latter, you'll need a complete new unit. I used Shimano UN55 cartridge b/b's on my bike. They're good quality, reliable units that cost about a tenner from
Wiggle. I guarantee if you look around you'll get the unit, a crank removal tool and a Shimano compatible b/b cup tightening adaptor for under £30.
The unit is simple to fit, as long as you make sure you get the same shell width and axle length, and they'll be plenty of video's on YouTube or advice from the friendly folks on here if you get stuck.
I'm all for supporting the LBS, but not when they're asking £30 for 5-10 minutes work!
