Need opinions on my bike's bottom bracket - is it loose?
jamsw73
I got my bike checked out after hearing some cranking noises coming from the bottom bracket. The noises occur occasionally whilst pedalling. Anyway the mechanic said the bracket has not been screwed tight enough, apparently not a wear and tear issue, it's something which the manufacturer didn't do, and this is what's causing the cranking noises. I've attached a photo here, apparently where the arrow is pointing, there shouldn't be a gap according to the mechanic.
What are your thoughts? Because I rang the online store where I bought the bike from, they looked at the photo and said that the gap is pretty normal for a tapered bottom bracket.
Tail End Charlie
Well, write it down boy ......
Difficult to tell, but it looks like there shouldn't be a gap there and it is loose. I presume the mechanic has now tightened it up, has the noise gone?
winjim
Smash the cistern
To fix it yourself would probably require buying a crank taker offer and a bottom bracket tightener upper. If you've just got the one bike they probably wont get used very often so you'd have to decide if it's worth it, you might just as well take it back to the LBS. However, £30 seems a little steep to me for what should be a relatively quick job.
A crank taker offer and a bottom bracket doer upper will cost less than £30.
Drago
Currently a tenner do a whole set in Aldi. Not exactly Teng quality, but ample for occasional jobs like this as they arise.
winjim
Smash the cistern
Yes, but factor in whether the OP can be bothered to work out how to use them or if they'd rather have someone else do it.
Is £30 right? It seems expensive to me but I've always done my own maintenance so I wouldn't really know.
J
jamsw73
cheers for the input guys on this, do you think though that there the bottom bracket looks loose judging by the photos?
raleighnut
Bear in mind both sides of the crank need to come off, the fixed cup side to screw it in cannot be done without slackening off the other side then readjusting.
