1. You shouldn't be riding on pavements in order to jump off them!
2. Have you checked that the tyre is seated properly at the valve? You need to push the valve up further into the tyre to make sure that the tyre seats properly at the valve where the inner-tube is reinforced.
		 ), now after fitting tyre and tube, I always run an old ice cream stick (luckily I’m fond of Magnums ) all the way round the rim on both sides of the tyre to check there’s nothing trapped 👍
