Hi, new to forum, Possibly somebody could help me. I've googled my brains out looking for a solution.
I was given a mongoose switchback 26" bike with a missing front wheel. I thought I could simply pop off the wheel from my diamondback mountain bike and put in the mongoose for a test ride but even with the quick connect skewer all the way loose the axle is about 1/4 to 1/2" too short. The fork slot metal on the mongoose is like 1/4" thick (much thicker than my diamondback). The distance between the inner fork is the same on both forks about 4" which I assume this would be 100mm QR axle but I can't undo the QR enough to get the axle in the groove and screw it back on. The axle doesn't stick out beyond the thick fork metal slot. Can I buy I longer axle? Is it possible get the wheel to work with both bikes using a spacers on the diamondback with a longer axle. If I got a long axle I imagine I would need a longer QR skewer? I thought a quick google search would give me an answer but I keep coming up empty. Looking for help! Thanks.
