Cubist
Still wavin'
- Ovver 'thill
They aren't that expensive right now, and they may well calm the chain down. The switch means you can choose not to have it on at all if you don't want. Yes, it stiffens the change a bit, but not massively- but mine are on XT shifters which are positive/crisp to start with. Also, the clutch is adjustable by unscrewing the cover and adding or removing spring tension, so you can always tune it to how you want it.@Cubist you think those clutch mechs are worth a standard triple setup? I seem to get more slap on the Kinesis, possibly because the back end is pretty rigid. The Shimano mech has a switch though, which demands a conscious decision and I also read it stiffens the change a lot.
