Sorry, but I think the numbers generated by the graph in that article are
absolute piffle!
The numbers for me work out at about 120 psi front and 145 psi rear! I once tried 105 psi front and 125 psi rear and had to stop after 5 minutes to let air out of my tyres because they were unbearable to ride on local bumpy roads at even those pressures.
I usually put only about 85-90 psi in the front and 95-100 in the rear but for a forum ride on Sunday I put about 95 psi front and 105 psi rear and found the extra pressure made the bike far less comfortable. I'll go back to my normal pressures for the next ride.
I spoke to a former pro-team mechanic about the subject of tyre pressures and he told me that almost everyone insists on using higher pressures than they probably should and no amount of talking to them would convince them otherwise. In my experience, that is true. One of my friends even insisted on putting 100 psi into a chunky MTB tyre. He learned his lesson the hard way when it blew off the rim on a descent ... (Mind you, he probably still puts 80 psi into a tyre rated at 55-60!)
People talk about the comfort of steel framed bikes, and the harshness of stiff aluminium bikes. I can make my steel-framed Basso horribly harsh by putting too much air in the tyres, and my aluminium-framed Cannondale a sweet ride by using lower pressures.
I say forget the graphs and what numbers other people recommend - just try different pressures for yourself and ride whatever suits you best. The bottom limit is when the tyre squirms about or you get lots of pinch punctures. The upper limit is what is safe. Somewhere in between is what you need and only you can decide where that is.
I definitely agree that the rear tyre needs more pressure than the front but a 10-15 psi difference is enough for me.
