Doyleyburger
- NCE West Wales
Try and drop your shoulders a bit, this will give a slight bend in the elbows which will help. I used to ride with my arms straight which made me ache around the neck and shoulders.
You may have to get some bars with more rise, then, if they do not have rise already.It does feel like I need to raise my bars but I don't think the stem is adjustable. How do I know what the correct bar height is or whether my reach is too long/short?
No I don't do stretches. I've only done 2 commutes but this weekend I've had quite a bit of neck/shoulder ache. So definitely something to do with the bike. It could just be that I'm not used to it, but my gut says it's something about ride positionDo you do any shoulder stretches or exercises? How long have you been riding, sorry if I missed that earlier.
Now that you've ridden it for a a while and have noticed what works and what doesn't, go back to your LBS and ask them to make readjustments. Shouldn't be a problem if you bought it from them. Clipless pedals etc may help but they won't address the real problem which sounds to me like bike set up and/or riding style. It may be as simple as not having a relaxed upper body while you ride.Is this normal? Or should I try and adjust my ride position? I had the guys in the lbs set me up on a turbo trainer to adjust everything when I bought it so I should be right
I'm a newbie commuter doing my first two commutes this week. So far I'm doing around 12-16 miles in each day. I'm experimenting with routes hence the difference
Apart from the obvious glute and leg aches, I'm getting a nasty ache at the base of my skull and across my shoulders. I assume from craning my neck a bit to look up whilst riding.
