personally I would check the easy things first , standing up to pedal can eliminate saddle , putting hands close together while pedalling might eliminate handlebars and stem , take wheels off and put back on ( tighten cassette while off ) could eliminate cassette and skewers - wd40 cleats as might be shoes creaking ,bit of oil on pedals might stop them creaking
once you find out where its coming from then anyone of them is an easy fix - wouldn't attack the bb straight away as its the hardest thing to fix and might not even fix the problem
also there's the bolts on the chain rings to tighten - its a pig to find a creak but it is nice when you are silent running
I have found that if there is a rhythm to the creak then it could be any of the above as you put pressures in different places when pedalling , if there is no rhythm then more chance of bearings on way out
a tapping noise was sending me mad once and I was convinced it was bb - only to find it was a long zip pull tapping on the zip
good luck
and at worse , if you've gone all over your bike tightening all things and checking cable ends aint catching at least you have given your bike a good looking at
