My rim has been compromised!
Andrew_Culture
Internet Marketing bod
This morning I had one of those rides where I was sure the effort I was having to make felt a little tougher than usual. Admittedly I'd gone out on a whim having only eaten a banana and I knew that my legs would be a little tired from the forty miles I cycled through a monsoon yesterday. But still, this morning's ride felt too much like hard graft, even when I was trying to take it easy.
When I put my bike (Mr Blue Bike, a Ribble Audax frame with mongrel groupset) on the work stand to 'Mickle' (clean and lube) the chain I noticed that the rear wheel was sticking against one side of the rear brakes. They are the sort of brakes that mount to the frame via a single bolt (do all brake systems mount that way?) so I figured the brake mount needed tightening.
Then I gave the wheel a spin and it appeared buckled. The wheels are Mavic MA3 rims laced to Shimano Ultegra hubs and as far as I know are pretty solid. I didn't mind if they did turn out to be buckled; they've had a hard time of it over the last few weeks and truth be told I quite like truing wheels (here's how it's done).
So I started giving the wheels a really good clean then noticed something I've not seen before:
Bum.
Mind you, I've done 1,910.2 miles on these wheels (according to Strava) and the whole bike was second hand when I bought it so I don't really consider that it owes me anything. The only question now is do I replace the entire wheel or just the rims and spokes? How many miles can one expect to get from an Ultegra hub?
Rohloff_Brompton_Rider
Formerly just_fixed
I've had that on mtb disc wheels with Mavic rims. Easy to replace the rim tho as long as it's like for like. Used to cost me £17 and I'd just put the rims side by side and undo a spoke at a time and move over to the new rim. Once done and tightened to somewhere very near by eye, my lbs used to charge me a five to finish it off properly.
Andrew_Culture
Andrew_Culture
I think I'm going to struggle to justify any other type of fix. There's quite simply nowt wrong with the hub (that I know of).
Davidc
Somerset UK
If the hub's bearings run smoothly and a close visual inspection shows no signs of deterioration why would you spend money on a new one?
I'd view it as a good time to re-grease the bearings (unless you've got hubs with sealed ones) but I'd keep them. My only extravagance when a rim needs replacing and I rebuild a wheel is a complete new set of spokes. A few of the old ones go in the spares box.
My older Shimano dynamo hub is now on its fourth rim and still going well.
Andrew_Culture
Andrew_Culture
All good to know! Ta!
matthat
South Liverpool
I had a stone wedged in brake block a few years ago which carved a nice groove into the rim, Riding home from work one night and the wheel just collapsed underneath me due to scored line in the rim!!:sad:
Globalti
bromptonfb's suggestion is the best. Tape a new rim alongside the old and transfer the spokes over.
