My Raleigh Bike. The Start.
Boon 51
Boon 51
Deal. Kent.
I don't think that those hoods will fit - from your photograph it looks like you have Shimano Action or Motion levers which have an awkward semi circular cover on the side - they are available from a US dealer but NOS cost $44 :ohmy:
Easier (and cheaper) to buy a "new" set of levers
https://www.ebay.co.uk/itm/SHIMANO-...h=item2abf41d6d2:g:kdMAAOSwXGRcHMb-:rk:4:pf:0
or
https://www.ebay.co.uk/itm/SHIMANO-...h=item3b26d7404e:g:W7wAAOSw6gdb2BWu:rk:5:pf:0
Black looks good for longer!
Good find. One states the left clamp is missing would this be easy to get?
Boon 51
Boon 51
Deal. Kent.
or
Not too keen on the white one's.. :smile:
It looks like a Cinelli 1A, its just where the anodizing has failed in places. As others have suggested just polish it out. There is a small problem but its only a niggle, if you polish the oxidation spots off you will find a satin brushed finish underneath. A lot of that finish will still be in good condition and the act of polishing will expose the aluminium under the anodized surface. You will have a patchy finish and be tempted to go the whole hog and polish everything above the steerer tube line. Without a machine polisher, wheels and soap it will take a lump of time to finish. If you did it and by hand then bite the bullet and use 600 grit silicone carbide followed by 1000 grit then polish, it will still take a long time.
If it was mine I would just take a green 3M scrub to it with some soapy water. I machine polished a Cinelli stem a few years ago and it looks dandy but the polishing exposed the manufacturing/casting defects and it still took detailed work to look right. The anodizing protects the alu from oxidation, it is in effect a controlled oxidation so you would need to keep the salt and other corrosive crud off it.
This was very corroded when it was given to me, so much so that the surface flaked slightly when rubbed with a finger.
You are welcome to come and practice both on my bikes and there shed ^_^
If I was to ask if a hand grenade thrown into your shed would actually make it look tidier Biggs?
There's a good YouTube vid on how to position the bike, cranks, pedal spanner and weight to remove pedals. Mind you the bloke in the vid I've seen is twice the size of me lol I guess you have a proper pedal spanner :smile:
If the pin is completely out then its a nightmare to get back in. The trick is to leave the pin just in the outer plate and flex the chain to separate. A new chain on a worn cassette / freewheel is liable to skip :sad:
So funny, my visiting friend who is mentioned in my contentious electric bike thread took a couple of links out of his chain while here, why I don't know because he only used the pedals to rest his feet on^_^. Anyway I handed him my chain riveter and went off to work leaving him to crack on. Ten minutes later, "how do you get the pin back in"? "You pushed it right out, oh dear". Took some serious accurate positioning and hand force to find a hold with good pliers.
