EltonFrog
I don’t think the brown will match the brown of the hood, keep it blackI was thinking of the hoods colour that's all.
A second opinion always helps I will keep the black.
it would be cheaper to replace the hoods to match the saddle than the other way around
Whatever is comfortable for you is 'right', does the bike feel better to ride?
Too big or too small?
IF the saddle height in your photos is correct for you, the stand-over should be fine. The bike looks good set up as is. *IDEA* - stand over the bike and see!
Too big.
The other bikes I've got apart from the Raleigh I went and measured this morning and had a bit of a shock.
1/ Evans Arkose 52cm
2/ Giant TCR pro 1 50cm
3/ Cannondale Quick 1 48cm.
4/ Raleigh 54cm
The stand over height's are all about the 760mm but could be less with no problem's ( Raleigh 800mm ). so a 750mm would give me a 2 inch lower crossbar if my adding up is right?
