Boon 51
- Deal. Kent.
Will send the bill by post , I CAN'T BELIEVE THAT
You better hurry up with the bill as I'm moving house to get a bigger garage..
You better hurry up with the bill as I'm moving house to get a bigger garage..![]()
Not my day today.. Next problem.
I have just fitted the 105 calipers to the bike and bung the wheels in and would you believe 3 of the brake blocks fit the rims and the 4th is short by nearly half inch. So what's that all about. FFS
Like this
is that not because the brake cable isn't fitted? the tension from the cable will balance the left side with the right.Like this
You have the quick release lever (left hand side) in the open position. Push lever down then adjust cable tension and brake position - loosen Allen screw bolt that fixes to brake bridge, rotate brake body until brake blocks are equidistant from rims then tighten to frame. Hope this helps, it looks like you have limited drop on the brakes, have you removed the wheel and put it back on in a different position?
Has somebody built the calliper out of two different brakes?
