Seen I bombarded you guys with so many questions about Specialized bikes recently, I though I let you know about the outcome as well.
Last weekend my Specialized Allez Triple (Size 54 cm, with a shorter stem for the handle bars) arrived.
I took it out for a little ride on Sunday and it was great!! I haven't ridden a bike in years and never really been on out a road bike before. But it was all a lot easier than I expected. Despite that London traffic.
I covered 8.5 miles to a train station further down the line towards my work and because the next train home was 45 min away, I went all the way back again (still the train would have been faster
I am really happy about this good start to a long and happy relationship with my bike, but I do have a couple of questions before I start using it on my (part)commute to work on a regular basis.
1. I am after a bike insurance. To add it to my home insurance would cost me about 10 pounds per month (for 700 pounds worth of bike and equipment). I was hoping to get it a bit cheaper somewhere else - any suggestions?
2. A stupid question about my pump
I bought a Topeak Master Blaster Mini DX pump (http://www.wheelies.co.uk/products-Mini-DX-Hand-Pump_1167.htm) which is supposed to fit the Presta valves on my bike. For some reason I can't figure out how, though. Looking at the valve and the bit of the pump that should connect to it, it doesn't look like a good fit to me.
I know that there are adapters out there for that kind of thing but reading the description about the pump on the internet, it sounds as if there's no adapter needed.
Does anyone know what the problem might be?
3. The third question regards the end of the gear cable that runs to my front derailleur. It sticks out so that on each rotation it scrapes along my crank (does that make sense?). The seal at the end already fell off.
I guess it is just a matter of loosening the screw and pointing it into another direction, but I am a bit worried that I might alter something about the gear shifting which I couldn't put right anymore.
And which direction should it point anyway? It can't point downwards because of the cogwheel, inside is the tyre, upside isn't ideal either. Do I just shorten it? Or should I simply ignore it?
I know it is only a minor thing but if I could set it right, why not.
Alright, that's it for now. Thanks.
).I am really happy about this good start to a long and happy relationship with my bike, but I do have a couple of questions before I start using it on my (part)commute to work on a regular basis.
:I bought a Topeak Master Blaster Mini DX pump (http://www.wheelies.co.uk/products-Mini-DX-Hand-Pump_1167.htm) which is supposed to fit the Presta valves on my bike. For some reason I can't figure out how, though. Looking at the valve and the bit of the pump that should connect to it, it doesn't look like a good fit to me.
