So, my new bike arrived yesterday - it was taking up the lounge when I arrived home from work.
Excited, I got it out of the box, got the pedals on easily enough, and then looked at the handlebars - wait, thinks I, I'm sure it said the handlbars would be 'turned', not removed!
So looking for instruction and finding none, I set about it with the supplied tool, and after a bit of swearing got the bars attached and the right way up. Yay!
So I took it into the garden and a problem immediately surfaced. Surely it can't be right that I can barely touch the ground while seated? With the saddle in it's lowest position? And why does the wheel hit the pedals when I turn the handlebar slightly?
Puzzling over this for a few minutes I realise the problem.....I had managed to put the handlebars on whilst the front stem was facing the wrong way - oops. So after a bit more swearing I got the handlebars off again, turned the stem round and reconnected the handlebars - finally the bike was ready for it's maiden voyage.
So dressed in my pyjama bottoms, t-shirt and crocs, I wheeled the bike up the side path, and took it for a quick (2 minutes) ride along my street. I'm sure bikes never used to be this wobbly when I was riding my BMX 20 years ago? Then again, I guess I never weighed 17st then either.
So initial impressions - much nicer then the BSO I had about 8 years ago. This one actually goes where it's meant to; breaks are really responsive - saddle is incredibly uncomfortable, but then mt behind has been very pampered over the years so I assume I'll get used to it.
I'm hoping to take it out for a slightly longer ride this evening after work if I can find anywhere to go - but Saturday afternoon is shaping up to be the first 'serious' ride of an hour or so.
Could this be the birth of another cycling nutter?
To be updated :-)
To be updated :-)
Crocs
You should invest in a good set of allen keys mind.
