Multi-tool (Dremel / Proxxon?) Advice Needed...
i looked at lidl one but have not brought one yet , anybody here has brought one if so let us know please
My best buy and invaluable for bike work. I tend to use mine with the bike on the stand to cut off mudguard stays and any other little job. The accessory kit is fantastic value and it's a good idea to buy a couple. For larger jobs, such as cutting alu bars, better to use a pipe cutter but there are hundreds of uses for this tool.
02GF74
I have the Black and Decker equivalent, must be 10 years old and is still going strong, despite a lot of use - ported 3 cylinder heads with it and motor got so hot I could not hold it yet till it carries on. Only had to replace the chuck spring in all that time.
Very useful kit for cutting slots in sheard bolts, removing bolt heads, cutting cable outers etc etc.
The tools come in three different diameter shafts and as you may have guessed, there is a different collect for each diameter of shaft.
