tdr1nka said:Oi, DannyG, you got that bracket off yet?
Is it like this?-
If it is, the clip is on the inside, so the only way to undo it is via the screw.
Then you can pull the clip, if you want to fit it to a bigger diameter.
Why didn't I think of thatTry taking the seatpost out and sliding it off. You'll get to the clip then.
Loosen the screw that holds the bracket together then do that, that's what I do.Dannyg said:Why didn't I think of that
Will try it after work - though the bracket is fixed on pretty tight.
Mine, doesn't have a screw - it just a curved bit of plastic with a cable tie like fastening.HLaB said:Loosen the screw that holds the bracket together then do that, that's what I do.
Guess that wont work then .Dannyg said:Mine, doesn't have a screw - it just a curved bit of plastic with a cable tie like fastening.
