Ming the Merciless
There is no mercy
- Inside my skull
More air required uphill.............slower crank speed.
So it needs a torque sensor instead. Or it just be tuned to listen to steam engine breathing noises.
Negative airflow?How about some glasses with a motor that creates an airflow to reduce pollen particles getting into the eyes and nose?
I can see you're not an engineerMore air required uphill.............slower crank speed.
Easily solved by routing the air supply via a tilt valve attached to the crossbar - full flow when at an angle of 45 degrees to the horizontal and falling gradually as as the angle reduces.You've to lean forward on some inclines round these parts.I can see you're not an engineerEasily solved by routing the air supply via a tilt valve attached to the crossbar - full flow when at an angle of 45 degrees to the horizontal and falling gradually as as the angle reduces.
Speaking as a spectacles wearer, wipers would be good too.How about some glasses with a motor that creates an airflow to reduce pollen particles getting into the eyes and nose?
Their weak point seems to be the all important seal against the skin not being complete.Have you seen R-Shields? I'd rather wear one of these than a heavy motorised mask.
https://www.r-shields.com/
Rather than a motor how about a big funnel that uses the speed of the bike to collect the air?![]()
