Breedon said:So when i come to a hill i should now use a calculator+slide ruler and a laptop to see if i can climb it, instead of just chucking it in a high gear and spin![]()
Surely you mean low?
Here's the short answer:-
Cadence-power-relationship during decisive mountain ascents at the Tour de France
Authors: S Vogt, K Roecker, Y O Schumacher, T Pottgiesser, H-H Dickhuth, A Schmid, L Heinrich
Readers: Mark Maritz
The aim of the study was to report the relationship between cadence and power developed by professional cyclists during high mountain ascents of the Tour de France. From the 10 cyclists (30 +/- 4 years, 178 +/- 8 cm, 69 +/- 6 kg) involved in the study, 108 ascents were recorded and analyzed using a mobile power measurement device (SRM Training Systems, Jülich, Germany). Based on topographic characteristics, the ascents were categorized into 1st and Hors Category (HC) climbs. During the ascents of the 1st Category climbs, power output averaged 312 +/- 43 W (4.5 +/- 0.6 W/kg) with a mean cadence of 73 +/- 6 rpm and a mean duration of 37 : 41 +/- 16 : 16 min. Power output averaged 294 +/- 36 W (4.3 +/- 0.6 W/kg) at a mean cadence of 70 +/- 6 rpm during 57 : 40 +/- 10 : 32 min on HC climbs. The maximal mean power for long durations (1800 s) showed a mean power output of 327 W and 346 W for the 1st and HC climbs, respectively. The evaluation of the cadence-power output and the distance per pedaling cycle-power output relationship shows that high power outputs are mainly yielded by higher pedaling cadences and higher gears.
International journal of sports medicine. 01/04/2008; 29(3):244-50.
ISSN: 0172-4622
DOI: 10.1055/s-2007-965353
Extract from a technical paper evaluating cadence when climbing.
It doesn't really surprise me to see 73 +/- 6 rpm and 70 +/- 6 rpm because that was the way I was taught.
It is interesting to note the W/kg figures of 4.5 and 4.3, a lot lower than the 7 target during training. The hills were 7 - 8%.
The Wattage outputs weren't rediculous either, so if there's anyone out there enrolled on a Sportive, you should be aiming at this standard
