Now along comes Johnny and opens his BB to replace the bearing inside. He takes the plastic cup off and sees inside that it is an 6805 RS/2 bearing. Bingo! he thinks and goes to the bearing shop and buys two 6805 RS/2 bearings. He fits them and finds that they are 1mm too thick (wide). He double-checks the code and sees that he did not make a mistake, he used the right code. He then measures the old bearing which is marked as 6905 and sees that it is only 6mm wide. Puzzled, he gives up.
Yes, I'm puzzeld now, Johnny see's he has a 6805 RS/2 bearings in his BB and orders those, but they do not fit correctly, so he checks again to see if he had made a mistake and he had not, but when he checks his old bearing, it is now marked as 6905?
I think Johnny would be better off going to specsavers so that he can read the codes on the bearing correctly the first time.
