I've said it before, and I'll say it again - the Mickle method changed my life. If I don't get a chance to do a proper clean of the commuter bike at the weekend, a quick Mickle and some air in the tyres makes Monday mornings bearable (almost).
I try to neither clean nor lube a new chain until it reaches the first 1000 miles or the first squeak, although this is not always possible through the Winter.
After that the Mickle method's a logical way to clean & lube until chain replacement. I average 3000+ miles per chain (SRAM).
When I rode cyclocross (mud/ sand /straw/ leaves on chain) I'd use lots of hot soapy water and a spray/ sponge to get grit out of the chain, dry with WD40 then re-lube. Mickle method for everything else (saves time and is plenty good-enough)
