Basil infused extra virgin is also oil but has limited use as a chain lube..
Quite right, volatiles in the basil reduce the viscosity of the oil. I use an unadulterated single-estate Tuscan oil on my Colnago.
I'm coming to that conclusion myself now! And after all, the chain is a cheap and relatively short-lived component anyway so it's not worth worrying about much in itself. But I guess I'm just keen to preserve my cassette and more especially chainrings as long as poss, and for the whole drivechain to look, feel, and sound spot on when zipping along.In my humble opinion, you're over-thinking it
That's all you use?! No wet or dry lube at all? It sounds beautifully simple, but I'm surprised it offers enough lubrication for a decent day's ride. Have you had no probs with cassette/chainring wear?So use nothing other than GT85 and a rag after every ride
I think the factory lube and the ceramic Muc Off lube I have prob are incompatible? So I prob should degrease first.2) No, not unless you're switching between completely incompatible lubes (usually wax and anything else)
Why didn't I think of that?! Thanks3) Yes, apply lube to the inside of the bottom run and let it rinse through
That sounds like a fantastic routine for someone of my OCD tendencies - i'd love to be able to do that! It's been suggested by some of our staff that we should have a shower room on site so I might push for the boss to get an airline and oil bath installed tooWhen i was commuting, i was fortunate enough to store my bike in my workshop. This left various bits of the day to keep the bike clean etc ect. on a weekly basis, sometimes more often I used to remove chain, wipe clean, lay on a bench and blast all the dirt out of the chain with a HP airline, you'd be amazed how much comes out, and keeps coming out. Once clean, i'd lay it in an oil bath for half an hour, then hang on a nail to drip excess off, then wipe wipe wipe and fit back to the bike.
Sounds like a faff and it would be at home, but i was at work and each operation only takes a few minutes so no loss to me.
I had a lovely clean, well oiled chain.....did it last any longer than just oiling and wiping...no, it didnt make a jot of real difference (i'm a bit sad like that, i used to record whaich make chain (tried em all), and what mileage i got out of it. No difference whatsoever in my experience
I use a properly "dry" lube on the summer bike (Muc Off C3 Ceramic) as I find it works well (with caveats - see below) and keeps the chain/cassette sparkling clean.
It's not oil... It's a liquid solvent carrier with a ceramic "wax". the solvent penetrates the rollers then evaporates and leaves behind the waxy coating.
I've found that it works best if the chain is cleaned and de-greased before initial application. I generally spray the chain with brake/clutch cleaner before use and allow it to dry out. Then apply several coats of C3, allowing each one to dry out for a few hours (or overnight).
Once lubed the chain feels slippy, but has no oily residue. It runs completely cleanly and doesn't pick up the black gunk/grinding paste an oil based lube generates. The chain, cassette and jockey wheels stay new looking and shiny and chain wear rates are no worse than using oil. Then all that's needed is a quick re-lube every week or so, as a bonus, as there's no gunk the weekly cleaning is a simple wipe with a dry cloth and re-apply.
However (there's always a however), it only works when it's not raining..... rain washes out the lube very quickly and leaves the chain with little protection.
Oh and the stuff is stupidly expensive.... although a small bottle does last for ages as you need very little.
But then this seems to make a lot of sense. I'd never thought that oil turns black because of the residues that it moves out of the chain rather than just because of the gunk it collects from the road.Oil flows back between pressure "incidents". We know this because it carries with it black steel residue and the fact that the oil turns black tells us that it is being recycled and pumped throughout the chain's tension and slack runs. Wax for instance doesn't turn black because the steel particles remain a the surface where they come from and never disperses into the rest of the lubricant.
However, I cannot ignore the term "dry" because it is so prevalent in bicycle lore. I prefer the term solid lubricant. This could also include the solvent-based waxes described by you that are technically liquid when applied but solid once the carrier has evaporated. All these suffer from longevity, as I described. Obviously this is not a problem if your re-lube intervals are short. How short? It depends on how solid the lubricant is. Wax allows metal to slide on metal within 10 kilometers or so. This is easy to observe since the chain makes a different sound as soon as the wax is displaced from the pressure faces inside the chain. A trained ear can quickly pick up that point.
@Yellow Saddle - the claims in the description here seem at odds with your assessment of dry/solid lubes - https://muc-off.com/lube/179-c3-dry-ceramic-lube.html
I'm not even sure if this C3 Ceramic stuff counts as a wax or not. I don't mind frequent re-lubes but 10km is just stupid, as you imply yourself. I can't find a full list of constituent ingredients anywhere but it mentions Flouro polymers and Boron Nitride. Looking that that would you say the claims of "reducing metal to metal contact to a groundbreaking low level" is just advertising bunkem? Or could this ceramic stuff be a better bet than wax and serve as well as oil but without the mess?
Assuming you can compare GT85 with WD40, they're much the same in use, but in actual properties...i don't know, but..Yes, GT85 and a rag after every ride, although I sometimes dispense with the GT85 if I'm feeling mean.
The drivetrain runs smoothly and quietly, although it will sometimes become noisier towards the end of a longer ride.
No particular problems with chain or cassette wear.
I don't clam to do millions of miles, and those miles are split over three bikes.
Neither do I claim my method will eke out the last kilometre from a chain.
It's not designed to, it's designed to do a reasonable lube job while leaving the chain appearing clean and shiny - which is what you asked for.
I did run my lube method past my mate Chris the bike mechanic.
"Good as any," was his slightly world weary response to such a fresh and interesting question.
I think he liked the little and often approach as much as the method itself.
Assuming you can compare GT85 with WD40,..
This seemed to work in that the chain and cassette lasted as well as I would have expected. I mention the cassette, @gbb because a worn chain takes the sprockets with it as the link length effectively increases. With an over-long link length, the chain's load all falls on the last sprocket tooth as it drags off it instead of being distributed over several and letting go gently.
What on earth is the Mickle method??
I've always been very unsure about how to clean and lube chains, and I'm an engineer! Having spent many years running an MTB every day over sandy moors and through a ford, which combination had the brake pads wear straight through the wheel rims, I settled on a quick and easy method, on the basis that quick and easy would get done. Use old cardboard behind chain wheels and chain, and underneath, spray copiously with good ol' WD40, spinning the pedals around, then apply a light oil on top. My hopes were, and still are, that the light WD40 will wash at least some crap away while not doing that nasty degreasing thing, and the light oil will then make it's way where it should. A light wipe with a cloth afterwards, bad in that it will force any surface grit back into the joints, but good because you need to not have excess oil on the chain for more crud to stick to.
