That is not MESH systems but mains Wifi expanders , again I had those with Virgin , utter tosh hence buying MESH devices .Thanks for posting this was looking recently for something to boost WiFi to garage and back garden.
However I'm sure I was put off the mesh when it said something along the lines of the electrical system all having to be on one circuit and the trouble spot, the garage, has it's own fusebox.
And does it work if your house has the modern type fusebox with the separate circuits and trips for different parts of the house?
This - I recently installed a wifi access point upstairs, set the SSID and password to be the same as the main router downstairs (but chose a non-overlapping channel), now we have a continuous network with no need to switch, the device just chooses the strongest available option.When you say extenders, have you tried Access Points such as Unifi Access Point Lite? You can set these up and name them the same as your main router and your devices will follow the signal strength. We have two of these to cover previous dead spots and work really well (for us)
Our house has the “modern” fuse box, our Tenda MW5 mesh worksThanks for posting this was looking recently for something to boost WiFi to garage and back garden.
