Sore Thumb
I normally wear standard cycling clothing everyday for the commute to work. However, you can't wear the clothing more that once due to the pong.
I'm thinking of doing some touring and will require to wear my clothing more than once.
I am considering getting some clothing with a high content of merino wool. Less of a pong factor.
I've been having a search and most so called cycling merino wool tops have merino wool as the lowest content of the other fibres used in the garment.
High content merino wool tops seem tone for general use. Which is ok but I'm concerned about the cycling position on a bike. Cycling tops are a bit longer to cover your lower back when on the bike.
So, does anyone know of any high content merino wool tops that will be ideal for cycling?
Red would also be good, but can't have everything.
Thanks
Thanks
