Stick with it.....I've just got into epoxy.
Not fixed anything with it yet though
There's no way I could match @ColinJ 's laptop epic. My attempts at fixing one ended in total failure.@slowmotion 'll put us all to shame.
I'm assuming you mean the liquid stuff like araldite..
The epoxy putty you can buy fixes all the stuff that the liquid stuff would run off from,
Actually both
I seem to have slightly stripped the threads in the cable housing of a set of forks.
The hole is way too small to helicoil and I don't want to be drilling into my expensive forks.
I used threadlock and at the moment, it seems to be holding.
Should it fail, the plan it to use the putty at the base of the hole, then drill and thread into that.
The liquid stuff I bought is JB Weld but not for that problem
