lazybloke
Priest of the cult of Chris Rea
- Leafy Surrey
Throbbing work surface?
Grief does funny things to ones memory, okay? Dont knock a man when he’s down. 😥Throbbing work surface?
Thank you Scot. That means a lot. 😭Wishing you strength in your time of need.
excellent. I did similar to extend my bike rack. I was lucky & found some random wire in my basement that was of the right gaugeI used a bit of stiff wire to bodge the bottle holder on my mountain bike. Ideally needs a spot of weld or braze but I don't have the equipment.
Split rings frommold key rings make excellent zip tabs.
I have a small AA/AAA battery tester which had a link connected to the end of it, so it could be hung from a belt etc. It had never been hung from a belt and never would have been - it lives in a drawer in my kitchen, alongside a mixed collection of batteries. The link has now been attached to the zip on my gilet instead...Good thinking! I must have one lying around somewhere...
Sat for quite a long time looking at that acronym! Must need more coffee.My current MI&MD is a Nespresso Aeroccino 3 frother. If these overheat in one spot, they die. But they die because there's a non-resettable thermal fuse in them. So, on Ebay, there's a guy who has put together either 1) a repair kit to install a new fuse, with instructions, or 2) a kit with a resettable thermal fuse and instructions. Then, if you trip it, you wait for it to cool, clean the burnt milk off the bottom of the cylinder, and by then, the fuse has reset. That version is what I'm doing. I'm taking it in slow time, as this is to be sold on afterward, and I want no mistakes. Personally, I think this kind of built-in failure should be outlawed, and the resettable made the standard...
I suggest that you turn around that nut and bolt or cut it flush. In a crash a protruding boot will make a hole in you. A mate of mine has a nice scar and memories of hospital food following surgery on his knee after doing just this with a seat clamp bolt on his commuter.excellent. I did similar to extend my bike rack. I was lucky & found some random wire in my basement that was of the right gauge
